Separation of Sulfur/Gasoline Mixture with Polydimethylsiloxane/Polyetherimide Composite Membranes by Pervaporation
论文类型 基础研究 发表日期 2014-10-14
来源 Chinese Journal of Chemical Engineering,
作者 ZHAO,Changwei,(赵长伟),LI,Jiding,
关键词 polydimethylsiloxane (PDMS)/polyetherimide (PEI) composite membranes, sulfur removal, gasoline,pervaporation
摘要 Worldwide environment has resulted in a limit on the sulfur content of gasoline. It is urgent to investigate the desulfurization of gasoline. The polydimethylsiloxane (PDMS)/polyetherimide (PEI) composite membranes were prepared by casting a PDMS solution
