饮水健康与基因重整
论文类型 基础研究 发表日期 2001-03-01
来源 世界水日—首届中国饮水与健康高层论坛
作者 金日光
摘要 金日光 北京化工大学   摘要:本文运用作者创立的“第四统计力学一JRG群子理论”,将门捷列夫元素周期律中的元素含水络合离子,按其亲电、亲核性标度值大小,结合其对生命体的作用功能,重新定量界定了八大类型的生命相关元素群及生命动力元素群。并揭示了元素含水络合离子的亲电性、亲核性标 ...
金日光
北京化工大学
  摘要:本文运用作者创立的“第四统计力学一JRG群子理论”,将门捷列夫元素周期律中的元素含水络合离子,按其亲电、亲核性标度值大小,结合其对生命体的作用功能,重新定量界定了八大类型的生命相关元素群及生命动力元素群。并揭示了元素含水络合离子的亲电性、亲核性标度值最大时,对生命体具有毒副作用的机理,及含d轨道过渡元素离子群亲电性标度值适中时,对生命体具有催化激活动力作用的机理。从理论上,彻底摒弃传统关于元素生命相关性研究的定性经验划分。作者在大量的实验研究基础上,指出健康饮水必须具备重氢含量少、多种有益生命健康的元素含水络合离子群、高能态等必要和充分条件。并对饮水影响遗传基因载体DNA的机理作了深入探讨,通过对洲A双螺旋结构稳定性生理环境条件的研究,揭示DNA、RNA合成、复制、转录以及重整的生理环境条件的两大决定性因素是氢键作用动力和色散作用动力,本文指出,氢键作用动力为主导,色散作用动力为辅助的生理环境条件,是人类基因区别于其他物种基因的重要依据。作者还从高能多元素矿溶液及其稀释液增强氢键作用动力的实验中,得出饮水健康对基因重整具有重要作用的结论。同时指出,保护饮水资源不受污染的重要性和迫切性。本文中涉及的重要理论概念,参见作者著作的《第四统计力学一JRG群子理论》一书。
Drinking-water health and Reformation of Genes
Prof . Jin Ringuang
(Beijing University of Chemical Technology,100029)
  Abstract: utilized the Fourth Statistics—JRG Sub-cluster Statistics Theory written by author himself, the hydrous complex ions of the chemical elements in Mendelyeev Periodic Table were quantitatively classified into eight kinds of element clusters of life power according to their eletrophilic scale values and the function to life body. When the eletrophilic and nucleophilic scale value reaches the maximum, the hydrous complex ions are harm to life body. When the eletrophilic and nucleophilic scale value is moderate, the hydrous complex ions have catalysis and can activate the power. Theoretically, it abandoned the traditional qualitative classify about the study of life elements' relativity. It was pointed out that healthy drinking water must possess the necessary and sufficient conditions, such as little diplogen, high-energy state and many kinds of hydrous complex ions which are good to life health. The mechanism of the effect of drinking water on the genic carrier--DNA was deeply discussed. It was found that hydrogenolysis motivity and dispersion motivity are the two crucial factors to physiological surroundings of synthesizing, copying, transcripting and reforming the DNA and RNA. The important proof that human's gene is different from other speciex gene lies in the different physilogical surroundings. According to the experiment of high-energy multi-element mineral solution strengthening the hydrogenolysis motivity, the conclusion was summarized that healthy drinking water has important effect on the reformation of genes and the essentiality and necessity of protecting water resource far from pollution. The related theory and concepts in this paper can be consulted in the monograph--the Fourth Statistics--JRG Sub-cluster Statistics Theory.
  近几年,我国围绕饮水的健康安全问题,己进行了广泛而深入的探讨,使越来越多的人意识到饮水对人体健康的重要意义。可以这样说,哪里有好水,哪里就有健康长寿的人群。这里有两个问题值得探讨:一是什么样的水是好水?二是好水究竟如何影响人体健康?
  一、关于好水的极念和该喝什么样水的问题
  根据大量的研究实证表明,好的饮水具有下列特性:
  1.好水中重氢含量少
根据现代科学理论和大量实验证实,重氢(D)与轻氢(H)的化学作用是非常相似的,但是重氢的原子核比轻氢原子核重一倍,其运动能力相当差,所以影响人体内生物化学反应速度,以至影响到遗传基因载体DNA的合成、复制和转录的速度,使人和动物多喝重水就会危害健康,甚至死亡。因此,好水中重水含量尽量要少。在地球上,冰川的水及3000~4000米下的深水中重水含量较少。而在地面上普通水中有>0.015%的重水,意味着在这种水中还有~1022个重水分子,对人体健康有很大影响,从这个意义上讲,尽可能喝一些重水少的饮用水才能对身体育好处。不过通常寻找重水少的饮用水较难,在这种情况下,可以通过高能活化的方式,减少重水的影响。
  2.好水中要有多种有益于生命的多种元素及其含水络合离子群
过去评价各种元素与生命之间相关性时,大家都想从门捷列夫元素周期律上获得有关信息,但是未能得到理想的启示。所以只好用定性的或经验来研究各种元素与生命之间相关性。比如,锌镁是有益元素,而铅汞是有害元素等,但究竟为什么?还是说不出多少科学的定量道理来。这就不能不要求我们从量子化学角度重新研究各种元素与生命之间的关系。过去之所以弄不清两者之间的关系,其主要原因如下:我们知道,门捷列夫元素周期律是一种单质的化学与物理性质的周期规律,没有直接表明它们对生命的关系。但是既然“水是生命之源”,那么首先应该把所有的元素放到水中,要考虑水溶络合条件下的元素离子对生命体的关系。这样的思考方法给了作者极为有价值的启示。作者运用量子化学理论提出了一个新的概念,即含水络合离子的电荷强度的标度值(ξ)。现设任意元素的离子在水中所表现的“离子半径(rw)”,与无水的“赤裸裸”的离子半径(ro)间有很大差别,由于前者亲和了大量的水分子,所以rw>ro,因此某一离子对外的亲电性或者亲核性主要与rw有关。因此某种离子的电荷比为:
  但是在生命体内所有离子都有不同的电负性(X),因此一个离子对外的亲电性总是表现为:
  上式中ξ值称为某一种离子含水络合状态的“电荷标度值”。当+ξ值非常大时,该离子与DNA、RNA或蛋白链之间亲电性很强,当│-ξ│值非常大时,该离子对DNA、RNA白链的亲核性很强。根据这一原理,作者重新计算了每一个元素的ξ值。
  用现有rw、X、±ξ的文献数据,计算出各种元素离子的ξ值,并根据ξ值大小,结合其对生命体的作用功能,大体分成八大类型(见表1)
表1 生命元素标度分类表 亲
电
性
新
核
性 元素类型 (x/rw).z 离子结构 有毒元素(V) +6.8~8.1 Ag+(+7.6);Hg++(+7.6);Cd++(+6.8);Pb++(+8.1);Tl+(+7.0) 生化过程中催化、激活动力(Ⅳ) +4.3~6.48
(Cu++(+6.46);Fe++(+5.94);Co++(+6.1);Ni++(+6.1);Mn++(+5.1);
Zn++(+5.44);Cr+++(+5.44);Sc+++(+4.3);Al+++(+5.1)
能量传递及其酶中心(Ⅲ) +2.9~4 Mg++(+2.9);Ca++(+3.4);Ba++(+3.6);Sr++(+4.0);Sn+++(+3.9);
La+++(+3.9);Ce+++(+3.9) 神经传递功能元素(Ⅱ) +1.7~3.2 Li+(+1.7);Na+(+2.25);K+(+2.64);Cs+(+3);Rb+(+3.2);H+(+2.4) 营养型元素(Ⅰ) ~0 C~0;N~0;P~0;S~0;OH-(10) 离子平衡(Ⅵ) -8~-1 I-(-8);Br-(-9);Cl-(10);F-(-11);OH-(10) 氧化离子(Ⅶ) -13~-19 NO-3(-13);NO-2(│>-13│);SO-4(-19);SO-3(-18) 有毒自由基(超氧化)(Ⅷ) >│-23│
  这张表定量地描述了不同元素与生命之间的定量关系,从中使我们得到如下结论。
  (1)凡是构成生命体结构的元素(C、H、O、P、S、N)均处于非离子状态,故ξ值趋于零。
  (2)当+ξ值不大时Li+、Na+、K+、Cs+、Rb+等元素均与人体内神经传导有密切关系。这里+ξ值不大,意味着这些离子与生命体的生物高分子(DNA、RNA、蛋白质等)之间的亲电作用力略小,所以这些离子能够担负起较快的神经传导作用。
  (3)当+ξ值变得较大时,M8++、Ca++、Sr++、8a++等离子与人体内ATP能量传递和氧化还元生物酶有密切关系。由于稀土元素的ξ值也接近上述离子的ξ值。所以稀土元素离子La+++、Ce+++’等在生命体中并不表现为有害元素。
  (4)当+ξ值变得再大时,包括了含d轨道的过渡元素的含水络合离子:Fe++、Co++、Ni++、Zn++、Cu++、V++、Cr++、Mn++等。这些元素及其含水络合离子最大功能是在整个生物化学反应过程中起催化激活动力作用。有的直接成为生物酶的活性中心;有的成为生物酶的激活中心;有的成为影响DNA、RNA的合成、复制与空间立体构象的介电动力因素,所以将上述元素离子称为“生命催化激活动力元素群”。这些元素的离子群有两个重要特点:一是具有微磁矩。在人体的各个不同部位都有这种带有微磁矩的离子群,所以人体的手脚和器官相对运动时容易引起电磁场的变化和生物电流,从而使某些人感受到某种“气感”和热感。这一类离子群的ξ值适中,对DNA、RNA蛋白质的亲电作用既不强烈,也不弱,这种状况使这些元素离子具有“能上能下”的基本特点和相应的催化激活动力的功能,对遗传基因载体DNA、BNA蛋白质的合成、复制、转录以及重整DNA、RNA空间立体构象及免疫性起主导作用。但是并不等于说这些元素对人类健康就没有害处,例如当这些元素处于过量时也不可避免地出现“只能上而不能下”的情况,所以过量也会中毒。
  (5)当+ξ值变得最大时,包括铅(Pb++)、镉(Cd++)、汞(H8++)、银(Ag+)、铊(Tl+)等离子。这些离子的+ξ值过大,对DNA、RNA、蛋白质的负电中心有强烈的耦合作用,以至 “只能上而不能下”,所以即使是在极微量的条件下,也会严重破坏人体内遗传基因载体DNA、RNA的正常合成、复制和转录,影响蛋白质的合成,因此这是极有害的元素离子群。过去由于没有这种定量的计算结果,尽管我们可以从经验上知道这些元素有毒,但是其根本原因还是不清楚的。现在通过+ξ定量地知道了其危害的根本原因,包括致癌、高血压、糖尿病等病症的根本原因。这是从阳电(+ξ)角度来研究不同元素对生命健康影响的重要依据。
  (6)上面讲的阳离子群,总是需要阴离子来平衡阳离子。所以人体内还有相当多的阴离子,如F-、C1--、Br-、I-,其中F-还可以进入人体骨骼及牙齿结构中;碘可以进入甲状腺体中:Br-使人镇静神经;Cl-与Na+,K+共同起神经传递作用或变为胃酸,加强消化作用。
  (7)在阴离子中还有SO4--、NO-3根等属于高氧化态,它们的离子半径较大,对DNA、RNA、蛋白结构的危害性不大,但是亚硝酸根(NO3-)半径相对较小,对DNA、RNA有相当的破坏作用,以至引起致癌。
  (8)最后负电性非常强的超氧自由基(O2-)是氧化能力非常强的离子。人体细胞中线粒体在转化为能量的过程中有一部分氧气(血液提供5%)转化成O2-,一旦有了O2-,它疯狂地“烧掉”DNA、RNA、生物酶及细胞膜等,使一个一个细胞死亡,不能再分裂增殖,以至使人老化、衰亡。所以这是从负电角度来研究O2-对生命健康影响的重要因素。
  由此可以看出,饮水中应该有一定量的2、3、4类元素群,特别是第4类元素离子,而绝不能有第5类及第8类元素离子群。从大量的研究实验中发现,古今中外能使人健康长寿的饮水中,都有Zn++,Mn++,Sr++,Ni++,Co++、Cu++、Fe++、V++等元素离子群,其道理就在于它们的+ξ值很适中。现在许多矿泉水就缺乏这些有益元素的离子群。
  3.好水还要具备高能态
  饮水中含有上述第4类元素离子是好水应该具备的必要条件。但还不是充分条件,现在让我们来看一看一些矿泉水和矿溶水的O17核磁共振谱(见图1):
  显然这种框架结构不利于水分子的运动,也不利于金属离子在生命体中的运动,大大减弱了它们渗透到细胞的能力。因此这种水仍然没有活性。现在许多矿泉水都有这个问题。某些国外著名的矿泉水的017NMR半宽幅也超过100Hz。它只是含有大量的HCO-3,有助于消化而己,别无其它功能。下面我们再观察一下各种饮用水的能级情况(见图3)
  由以上可以看出不同的水有不同的能级状态,从中可以看出:
  (1)纯净水的017NMR最宽,说明水分子和水分子串联起来成为线团构象,不利于水凝聚体被细胞吸收,即使吸收了,也稀释了细胞质的盐分,甚至进入到细胞核中,影响DNA双螺旋结构,使DNA双螺旋解体,失去遗传功能。
  (2)阿拉斯加100多年前发生过史无前例的火山爆发,当时原有的北极带生命体全部消亡。但是大量的熔岩溶解于水中,使水中含有大量的高能态过渡元素离子群,变成了高能活性水。所以那里没有过多少年就形成了崭新的生态体系,出现了各种珍奇的动物和各类五彩缤纷的鱼群,各种花草和树木,这说明那里的水起了很大作用。作者通过化学分析,知道了那里的水中含有Zn++,Mn++,Co++……等生命相关元素,且017NMR半宽幅变得相当窄,即有高能态活性结构。
  (3)巴马县长寿村(67Hz),海南岛火山矿泉水(86Hz)也有较高的能态及一些有益于生命的一些元素。这些元素都具有良好的生物化学反应功能,饮用后可以使人们健康长寿。
  (4)在火成岩矿中,通过高温注氧和催化作用可以得到高浓缩的矿溶液,当其溶液通过很强的交变强磁驱动的超声纵波场时,这种浓缩液稀释而成的高能水也会有20多种生命相关元素,而且Ol7NMR达到50Hz~60Hz,说明这种水确实达到了高能多元素矿溶水的水平。中国预防科学院的课题组也检测了这种水的017NMR,确实使半宽幅变得很窄。
  4.好水喝出健康来
  这是判断饮水是否健康的重要表现形式。通过几年来高能水的试饮,效果良好。凡是长年累月地喝高能水的人,包括军人和学生,都反映身体的免疫力有所增强,很少得感冒;糖尿病和高血压患者都有明显的好转效果。因此尽管高能水不是药,也不是保健食品,但确实起着有利于健康的作用。目前全国各地已有20多家生产高能水的工厂,而且正在向全国各地推广和发展。相信2l世纪人们的饮用水将向着高能活性水的方向发展。
  二、好水究竞如何对遗传基因进行持续重整,使人更健康呢?
  为了说明这个问题,先简单介绍一下人体细胞结构:分子生物学已指出细胞有细胞膜,膜内有细胞质和细胞核。在细胞质中有各种氨基酸、生物酶及其活性中心的金属离子以及游离的各种金属离子含水络合物,还有DNA、RNA的基本结构单体鸟嘌呤核苷酸(G)、腺嘌呤核苷酸(A)、胸嘧啶核苷酸(T)和包嘧啶核苷酸(C)等。
  在细胞中还有细胞核,由膜(称核膜)来包围着,膜上有许多小孔(称核孔),便于细胞质流通。膜内的细胞核,就是人类遗传基因载体DNA双螺旋结构,常以染色体形式存在。人是否健康归根到底要看细胞核里遗传基因载体DNA序列和立体结构是否保持高度的“尊严”。现代分子遗传学已证实人类的癌症、爱滋病、高血压和糖尿病等病症都与DNA有直接关系。所以一切影响DNA的合成、复制、转录、构象的微观因素都会影响入的健康状况。现在只举一个例子,说明水是怎样影响人类遗传基因DNA的。
  为了说明这个问题,请大家先看一组实验结果。在生物化学中有一个界定,当氯化钠为0.2克分子/立升时,称之为生理环境条件。此时随着含不同含量的(G+C),其DNA双螺旋结构各有各的特定熔点。在一定的(G+C)含量条件下,熔点的高低反映DNA双螺旋结构的稳定性和完整性。近年来国外分子生物学实验得到极为有趣的结果,当他们向细胞里渗进各种不同浓度的氯化钾溶液时,DNA双链螺旋结构的熔点有所提高,可以用紫外光谱来观察其变化的结果(见图4)
  图4可以看出:
  当接近纯化的水分于进入DNA双螺旋时,就在相当低的温度下解体成两个单独的链了,此时相当于细胞衰亡。
  当氯化钾的浓度越高时,双螺旋解体所需要的温度越来越高,表明氯化钾对稳定DNA双螺旋结构起着非常重要的作用。这是因为钾离子(K+)渗到DNA之后,沿着DNA双螺旋结构的主链,以正电“离于氛”的形式,进一步中和主链上的磷酸根负电荷,并从双螺旋“碱基对”处夺取水分子,使双螺旋进一步得到重新整理(重整),使双螺旋结构更加规整。
  但是当用氯化镁宋代替氯化钾的时候,我们发现了非常有趣的现象:即Mgcl20.4克分子/升相当于KCl 1克分子/升的作用,这就是说以少量两价的镁离子(Mg++)可以顶得上几倍浓度的KCl。这是由于含水络合的镁离子ξ值高于钾离子ξ值(见表1)所致。鉴于这种情况,我们又用从天然矿中抽溶的Mn++,Fe++,Ni++,Zn++,Cn++等混合溶液来作相同的实验,其结果这些溶液的浓度为0.25的平均克分子/升时相当于KCll克分子/升的效果。由此可以看出,当各种过渡元素离子的ξ值比镁再大一点时(见表1),这些生命相关元素对DNA的重整效果非常显著;相反地用有毒元素PbCl4和HgCl2时,它们的浓度到0.1克分子/升时整个DNA高分子链干脆沉淀混浊,就很难测出准确的熔点,此时细胞核也完了。从以上的实验结果中可以看出,上述第4类生命催化激活动力元素的含水络合离子群就具有重新整理DNA的功能。许多文献指出,当生理环境盐(NaCl)的浓度越高(>2mol/L)时B型DNA的构象变成Z型DNA构象,即变成具高免疫性的DNA结构。作者正在研究上述多元生命相关的元素离子溶液对形成免疫性Z型DNA影响的问题。实验表明多组元素离子对由B型转化成Z型具有明显的协同作用。所以生命动力素含水络合离子具有促进细胞免疫的功能。这也就是为什么生命动力元素含水络合离子对人体健康有好处的微观根源。为了进一步说明这一点再看下列实验:
  一是高能多元素矿溶液对增强人体血液的免疫功能有显著效果。作法很简单,从一个人手指针刺出一滴血放到20000倍的Gaston血相显微镜上观察免疫体的数量和大小,然后将上述高能多元矿溶液稀释到可饮用的水之后,喝一杯水,经30分钟之后再观察血相,可以看出大幅度提高免疫体的数量和运动能力。内蒙古通辽市一所学校,喝这种水的4个班级的小学生冬天普遍没有得感冒;在石家庄市,500多名消防队员长期饮用,也大幅降低了医药费用开支,显然免疫力增强了。
  二是深度刀伤的裂口用高能多元素矿溶液来消毒和保湿,没有几天伤口就痊愈。这里使我们感到最有意义的是,几乎看不见任何伤痕。这种原位完全修复远比用其他的消毒剂和治伤药好得多。在这一修复过程中新生的细胞、新生的血管、新生的毛细神经都按原样来重新排列起来,填满了原来大裂口,而且最后几乎看不到裂口的痕迹。这就说明深度创伤的皮肤是完全可以恢复到原样的。由此可见,高能态多元素矿溶液中含水络合离子群不仅能够很好地整理整顿遗传基因载体DNA,而且进一步催化激活细胞核,加速分裂和增殖,并按全息原理回复到原样。所以对伤口而言,上述高能多元素矿溶液成为使伤口恢复具有最佳的生理环境条件。
  目前在治疗深度伤口方面还没具有同样效果的其他方法,这也直接证实了国外学者提出的“生理环境决定论”。至于为什么由生理环境来决定伤口的痊愈,从作者提出的理论来看是很容易理解的。我们知道人类遗传基因组由30亿对碱基组成,但是其中只有四种碱基(G、A、C、T)的这样排列或那样排列,构成了人类特异的遗传基因组。最近从六国学者公布的人类基因组研究成果来看,人类基因比线虫多一万个基因,比果蝇多两万个基因。许多人说人类也不过如此,但是这种看法是大错特错了,他们没有看到背后真正的特殊价值。作者通过详细的计算,得出任何遗传基因的形成都要靠四个碱基的氢氢作用动力和色散作用动力,前者具有高度的方向性,后者具有无方向性。人类不同于其他生命体的最根本点在于,人类最重要的遗传基因是由严格方向性的氢键作用作为主导动力,而色散作用则为氢键作用动力前前后后加以辅助,起着协同作用。这就是万物之灵的人类的最高尊严。但是在生命体中非常低级的大肠杆菌的遗传基因,则是由色散作用作为主导动力的,而氢键动力则处于很次要的地位。至于果蝇,当然要比大肠杆菌高级得多。在果蝇的遗传基因中巧妙地把氢键和色散作用动力搭配起来,从而使果蝇的遗传基因排列方式介于人类和大肠杆菌之间。所以不要只看表面上的基因数量,要看什么样的内在动力起主导作用。那么为什么有些物种是以氢键作用动力为主,有的则以色散作用动力为主?这个问题实际上是由生理环境起决定作用所致,即生命催化、激活动力因素来决定的。我们很容易想到当生理环境为纯水时纯水分子与四种碱基接触,水分子把四种碱基的氢键官能团全部掩盖,这样四种碱基失去了氢键排序的动力,只能靠四种碱基所固有的色散作用动力作为排序的动力。相反当生理环境为含有许多金属离子的水溶液时,水分子不再同碱基上的氢键官能团作用,此时四种碱基的排序将由四种碱基的氢键作用动力大小顺序来决定。从而形成由氢键作用为主以色散动力为辅的高级物种的生命体,甚至形成人类基因组。因此,生命体所处的生理环境就是通过内因让这样或那样的作用动力起作用。正因为这样的缘故,在修复创伤时就需要由各种生命动力元素组成的矿溶液,它不仅对已有的DNA起整理整顿作用,而且还能不断地复制DNA和增殖细胞,最终把伤口修复到原样状态。这种完整修复的实例还很多,比如“贲门糜烂”也是一种伤口性病灶,严重影响人的消化,甚至有可能转化成不治之症。对这样的病也可以通过不断饮用上述高能多元素矿溶水的方法逐步调理,最终达到不留痕迹的地步,这也说明这些高能矿溶水的多元素离子群,对糜烂细胞的遗传基因载体DNA进行整理整顿有密切的关系。这种高能多元素矿溶液也可以治愈非要手术不可的肛周脓肿,也是最后不留痕迹。
  从以上的讨论中可以看出,好的饮用水,从根本上来说是与人的遗传基因载体DNA的持续不断的重整、复制、转录,以至形成相应的蛋白质合成有密切关系,直接影响人体的健康,这就是为什么提倡喝好水的根本原因。但是有些学者否认喝好水的必要性,他们认为水主要用来解渴,至于人体所需要的各种生命相关元素均可以通过从各种主食和副食中摄取。这似乎有一定道理,但是这种方式非常缓慢,且人体很难直接摄取生命相关元素群,特别是生命动力元素群。从血相的检测中发现喝水是最直接、最快的方式,所以喝好水是健康长寿的最有效方法。根据同位素检测方法,QRS—FAFA仪的测试表明,尽管水经过一系列纯化、净化过程,但是水所经历过的历史信息仍然留在水中。只有经过高能交变强磁场及其高能超声场的作用才能彻底消除水的先史遗传基因痕迹。从这个意义上讲,保护饮水资源不受污染是极为重要的。目前国内有大量的纯净水生产,在生产过程只要加点上述高能浓缩矿溶液,这个水就可以变成高能活性水。在各种矿泉水中,有的虽然有不少有益元素,但能级太低,饮后对健康影响不大,对这种矿泉水还有必要提高其能级,使它真正起作用。
  作者介绍:
  金日光 北京化工大学学术委员会主任、北京群子生命动力技术研究所所长
  我国著名分子科学家,流变相态学及其工程技术创始人。现任全国政协常委兼民族宗教委员会副主任、国务院学位委员会学科评审委员会委员、国家自然科学奖评审委员会、国家重点学科及一级学科首任博士生导师、北京市人民政府专家顾问、北京化工大学学术委员会主任、北京群子生命动力技术研究所所长。
  90年代初,金日光教授创立的“群子统计理论”,被国际TUPAC大会正式接受为欧洲三大统计力学之后的“第四统计力学”。并首次将“第四统计力学”应用于生命科学研究。在“生命动力学及其工程”领域取得了重大突破。
  一.首次创立以“水是生命之源”为理论前提的《生命元素标度分类表》,将生命相关元素的含水络合离子,按其电荷亲和性标度值,定量界定为营养型、神经传导功能、能量传递及酶活性中心、生化过程中起催化激活动力作用等八大生命相关元素群体。从理论上彻底摈弃元素按必需、有益、非必要、有害、毒性和宏量、微量、痕量、常量的传统经验性划分,具有极高的理论价值,不仅为“水是生命之源”提供了科学的论证,而且为生命科学的深层次研究奠定了理论基础。特别是关于生命动力素的理论定量界定,为人类基因研究开辟了一条崭新的思路。
  二.从某些火山地区水质演化的显著特征得到启示,发明了生命动力素(高能态矿溶液所液)及其制备技术。应用开发和实验研究表明,运用生命动力素制备的饮用水,具有催化、激活生命动力的高能态和高活性。该成果经国家权威部门坚定,属国内外首创,世界领先水平。在研制发明生命动力素的基础上,金日光教授首次将生命动力学概念引入基因研究并取得突破性进展。他指出,在人类基因序列中,保持基因健康和重整的基因内聚能动力是氢键作用力破坏基因健康的内聚能动力是色散作用力,据此他又研制发明了具有基因重整功能的群子源整遗素。从生命动力元素含水络合物的催化、激活动力角度,使基因内聚能环境保持均衡持久的氢键作用力,有效重整基因,实现人类健康长寿的梦想。
